plate heat exchanger
phosgene
Member Posts: 8
in Geothermal
I have a plate heat exchanger in a weird set up.
it is from the 80s wondering what the temp rise and pressure drop should be?
This is actual hot water from the ground tied into several buildings around town.
pressure on return line and supply line
I will try that,Thanks
Thought there might be a general rule of thumb0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
