Low Water Cutoff
dc07736
Member Posts: 15
Hi,
I am going to buy a new Low Water Cutoff - 24 volt
What would you suggest?
Have 100 year old system. Historic house in Kingston NY
20 cast iron radiators - one pipe system
Install used Burnham steam boiler 142,000 btu
Thank You
DC
Thank You
DC
Hyrdolevel safgard0
If you have a tapping in the boiler at the right location, a Safgard LWCO is a good option. If the boiler does not have a tapping in a location appropriate for the Safgard probe, the McDonnell Miller #67 LWCO is probably your best bet.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
