Triangle Tube Prestige Solo 110 Boiler
Johnel
Member Posts: 1
Had a Triangle Prestige Solo 110 boiler installed a few years ago. Worked well until two days ago when the house temperature dropped to 65 degrees. The radiant heat floor turned cold. Had plenty of hot water from the boiler. No error code, but the reading on the display read 3 85; meaning the central heating was supplying only 85. This was not enough to heat our large house with the temperature in Utah around 22 degrees. I listened to the boiler which was on at all times trying to heat the house. I heard water dripping from the heater inside the cabinet. A repairman came by and drained the condensation trap that was overloaded with water and debris. After draining and cleaning the trap, the furnace output returned to its original state; ...nice and warm.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
