Flow control
BillAllen
Member Posts: 103
in Gas Heating
Installed a Navien 180 combi. 1 zone fine HW fine but the other zone no flow. T stat calling red light on on TAco SR 502 calling for heat. Circ was on when I left the job heat coming up good. Customer calls no heat. No blown fuses on taco board. I am suspicious about the IFC little plastic flow checks you put inside circs. Just started using them wondering if this is the problem. Could be air although I bled good. Anybody have problems with these types of flow checks? THX
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
