What is this?
Rich_43
Member Posts: 7
This was found in the basement of a house built in 1693. This is a better picture. It shows Open, Closed & Check positions.
Clothesline reel?All Steamed Up, Inc.
Consulting1 -
How about a picture of it on edge (90 rotation).
It is familiar somehow.....I'll go look in my garage .0 -
This is a picture of the other side. What doesn't show in either picture are the words Open, Closed & Check.0
It says "Open" "Check" "Closed" on it, but what does it say on the back rim?
I see writing on it
To me, it looks fairly modern, 1920s or newer?Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment-1 -
Where do you see that on that stove !?Fred said:Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment-1 -
That's a very similar vent/damper in the middle of the top door. Here's another one: http://antiquestoves.net/dir/antique-stoves-for-heating/baseburner-cylinder-stoves/kernan-globe-112-antique-stove-detailChrisJ said:
Where do you see that on that stove !?Fred said:-1 -
I don't think the item the OP has is a damper.
@ChrisJ Here is one on a kitchen stove flue. http://antiquestoves.net/dir/buy-a-cook-stove/antique-stoves-wood-and-coal/othello-antique-cook-stove-detail
I can't say what it is but I do think it is a damper off of an old stove of some type???-1 -
The material looks too thin to be a damper for any fire flue, IMO.
But maybe a damper/air vent for the baking oven side of a wood burning cook stove or a roaster/broaster type pan.
Things built in the 20's & 30's even proclaimed "Made in the USA", even if there was no import completion for most items.2 -
It looks like a remote control for a damper, not a damper it self.JUGHNE said:The material looks too thin to be a damper for any fire flue, IMO.
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment1 -
That is why I asked for the 90 degree edge picture, to see if a chain would fit into the pulley (if it is one).
(ChrisJ, if it is a remote control, I can't see where to put the batteries. )0 -
Sorry, I didn't intentionally ignore your request for a picture of the edge. I'm just not near the object any longer.
Thank you for your help.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
