V155 sticking
Member Posts: 3
My mother has a converted coal to gas gravity furnace with a Honeywell V155 gas valve that occasionally sticks open. The mechanism seems to be free. When it sticks any vibration sets it free.
So.........you should have it replaced, right?
You need to get some Honeywell "FINOL" and insert a few drops into the small cups supplied on the valve. This will lubricate the valve and it should resume normal operation.
The V155 valve is an old Series 10 gas valve and it is motorized0 -
Lubrication doesn't seem to eliminate the problem0
The only oil that will work is FINOL from Honeywell. Otherwise you will need to do a change out. Series 10 (DPST three wire) can be converted to Series 80 (SPST two wire) just drop the red wire. The pilot can be converted over to a thermocouple set up using the same bracket that the existing pilot is apart of. Honeywell VR8300A with a Q314 A pilot.
You could also convert over to Powerpile using the same pilot with a Q313 pilot generator.
OR
A new furnace.0 -
I'm working on the same v155 setup in an old coal to NG conversion gravity furnace. I see that the valve can be replaced with a VR8300. What all does this modification entail? What other parts are needed? Is there an adapter to go from the new combo valve to the existing 2-ear flange going into the burner port? I have in hand a new VR8300A, new pilot tubing kit and new 36" 30mv thermocouple.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
