Aquastat Relay L8148E
grovestreet449
Member Posts: 2
Hello, I have the above mentioned relay and it only works if I push in the wiring harness from the RVGP-KS-7BKF damper, wondering if might be loose solder in the harness. Would it not start if there was a problem with the damper Anyone have any input or troubleshooting advice? thanks
Tim, have you ever replaced the wiring harness or tried to resolder the connections?0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
