A Leak That Is Driving My Crazy
Rich Davis_2
Member Posts: 117
I designed and installed a hot water heating system about 4 years ago. It's a single zone with 4 loops using a TT PS 60 boiler. I"ve had a problem with a small leak, trying to find it. If the system cools down to ambient temp it will lose pressure, to the point that the boiler won't fire when with a call for heat. I manually feed the boiler, I open the fill valve for 2-3 sec it's up to 12 PSI and everything is fine as long as the system stays hot/warm. It's plumbed with sweated pipe. I've been over that system 10-15 times looking for sighs of a leak no luck. The question is, can I put some kinda dye in the system that will show up a leak.
Do you have baseboard heat or radiators? Do you have a compression tank on your system? Is the boiler not firing due to the low water sensor?0
you might need to do a loop by loop pressure test. If you can isolate the loops from the boiler and piping, take them up to 60 psi or so.
Small pin hole leaks are usually those slow gradual type. as the tube warms, sometimes the leak a bit more.Bob "hot rod" Rohr
Living the hydronic dream0 -
Thanks for the replys, gets the ol brain cells working. When I service the system before heating season I always check the air pressure in the tank. The next time I'll remove the tank and drain it and start over.0
Kinda back to the original question: is there a dye available to help me find the leak. Thanks0
Food coloring works.
Most auto parts stores have radiator leak detection dyes.
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
