Navien NCB 180
BillAllen
Member Posts: 103
in Gas Heating
I have a proposal to install the Navien NCB 180 in a crawl space. I have 48 inched to work with the unit is 28" high and I can make my own primary loop below giving me needed spec below. The 2" PVC vent is 2" using a street 90 to the outside might get me the clearance I need to install the unit. I will bring all my utilities on the newly wooden constructed wall on right side. I'll gladly accept any thoughts before I begin. My main question is space, do I have the space to install short of going to my supplier and laying out the unit from the box and measuring. Cheers.
You should have plenty of room. The primary loop doesn't have to be directly under the boiler you can come out of the boiler and 90 to the left then do your primary T's. You can use the left hand wall space to lay out your piping. You just have to get creative. Can try google images to get ideas.0
Thanks. Have you done one close like this? What is your knowledge of this?0
can be done...wear your knee pads...they suck...may want to verify with navien in reference to the street 90 off the top..0
The Navien installation is turning out well. I have about 11 inches to work with at the bottom.0
Circs on the supply or return? I'm not sure it matters with the Navien??0
The boiler circ should be on the return; the system circ on the supply, pumping away from the PONPC.Bob Boan
@BillAllen
Circ should always be on the supply.
I have installed many NCB combi units. Never with a 4' max height, but can generally get every thing to fit in a 4'x4' area. I saw a guy in instagram install one with about 2'x4' area it was extremely tight. I have no idea how he did it.
The DHW side is a little tight for my likings. You will either have to offset the valve kit with nipples and couples or turn them in towards the wall. Where it looks like the relief valve will hit the wall so to say.0 -
Doesnt this boiler have it's own internal circulator? Only thing you should need is a system circulator. And pumping away is the recommended practice...0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
