Minneapolis-Honeywell
Member Posts: 3,979
mixing valve installed in 1950 and still going strong. Serving copper tubing in the floor downstairs and copper tubing in the ceiling plaster upstairs.
4
love that gauge too! Thanks for the trip down memory lane.Bob "hot rod" Rohr
Living the hydronic dream0 -
After digging around the controls a little bit more, I came to find out that the boiler is controlled by a Honeywell aquastat below the eaves on the east side of the house. The original boiler was probably something with a high water content like one made by American Radiator Co., but it has since been replaced with a Munchkin. The Munchkin complains when the aquastat turns on the boiler, but the thermostat hasn't turned on the circulator. I'm tempted to make it a constant circulation system.
This is the oldest outdoor reset system I've ever seen. Those engineers at Honeywell were mighty smart.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
If it's the one I am thinking of they were pretty common. Looked like an aquastat had two bulbs 1 outside air 1 in the boiler. Problem always the capillary length0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
