Plugged Takagi
Gary Jansen_4
Member Posts: 77
Don't see many of these used as a radiant source. But got a call today from a homeowner asking if I would mind being the 3rd guy in on a problem. 1st guy installed pressure switch, 2nd guy installed a new fan. 10 year old Takagi Jr. Nobody bothered to open the thing up and actually look at burner and heat exchanger. Pretty ugly. Burner was fairly easy to clean up. Heat exchanger is a whole different can of worms.
Copper Fin type heat exchanger. Completely plugged from byproducts of combustion, as well as severe condensation.
Exchanger is encases in a bluish/green rock hard quagmire.
Today I removed heat exchanger, figuring I would hit it with some chemical cleaner and a good water flushing.
Started with CLR, then a citris cleaner, then Rydlime, then a commercial descaler.
Every time I flush with water, I get a blue/green discolored slurry out of the unit.
But after 3 hours of cleaning, soaking and flushing, I've really gotten nowhere.
Sitting here tonight debating......
Do I dare try an acid based cleaner of some sort? Or did I go to a muriatic acid, or stronger? Sulpheric?
Looking for some advice.
Thanks Gary
Thanks Gary
Ick. Your best bet is going to be muriatic (hydrochloric) acid. And lots and lots of patience. And acknowledge a very real risk of significant damage to the heat exchanger. The blue green colour is basic copper carbonate (maybe with a little sulfate for good measure) -- and the copper comes from the fins.
And it may not solve the problem.
Be careful. Strong acids aren't good for you. Glass containers... good ventilation.Br. Jamie, osb
The way you wrote it I am confused if you are talking inside exchanger or outside.
Pretty sure you mean outside of exchanger. I would mechanically clean with some media blast or CO2 dry ice. You can buy a cheap sand blaster and crushed dry ice.
Hello, Might be worth looking at the cost of a new heat exchanger if you can get one. The problem with fixing the current one is nobody can accurately guess the remaining life in it. You get to be on the hook. I really like to keep heaters going, but there is a limit...
Yours, Larry0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
