Couldn't delete the post so this
tokinturtle
Member Posts: 4
Should be able to delete
You won't find a direct replacement for that. I'm not even sure that setup still meets Code.
It might be possible to upgrade to a current model gas valve unit, but doing so is not a DIY proposition. You will need to call a pro to handle this. Click on Main Site above, then Find a Contractor and follow the instructions to find someone who can help you out.All Steamed Up, Inc.
Consulting0 -
He just might have saved your life. Theirs a reason the parts are no longer available.tokinturtle said:The local American standard/trane guy was worthless.
120K input?
40 - 50 years old? (Maybe Older)
Well ****. Thanks guys.0
@Steamhead nailed it. It's time for that set-up to go, easily 50-60 years old. You need someone that knows what he is doing to convert this to a new gas valve & ignition system or consider replacing the boiler0
Got the local boiler expert on it tuesday. They're going to inspect and possibly retrofit or replace. Thank god for woodstoves, and thanks for the help fellas0
Went on a homeowners insurance call Nov 2014 where the homeowner complained he found that the boiler door had blown across basement (and left a nice dent in concrete wall) and thought that might be why he wasn't getting heat....
After regaining composure, tried firing boiler for temporary heat OA was -10 at the time, opened main gas cock briefly and heard main valve open and release gas without pilot. This boiler from 1912 had an original gas valve with EXTERNAL springs!!!
For kicks and giggles I checked to see if they could cross-check a replacement valve..... imagine my surprise.
Wont risk my license to reengineer a boiler over 100 yrs old.
maybe if it were mine and had no kids....
Tech retrofit a new gas delivery from shutoff to burners. Burners were a more recent fix. She's running strong again. Again, thanks for the advice fellas0
Looks like from here you got some flame roll out issues....Hopefully that was looked at....What were the combustion readings like...0
Combustion test is critical.0
That entire pilot safety and gas valve can be replaced with a combination gas control. Have your service tech contact me and I can give them the part numbers to accomplish that.
The other alternative as already suggested is to replace the boiler.
My e-mail address is gastc@cox.net.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
