Coffee with Caleffi™ Documenting Hydronic Systems
ENyffeler
Member Posts: 5
Thursday, Jan. 26
12 noon CST
Hydronic heating and cooling systems can create challenging maintenance situations for those not familiar with the equipment or how it has been assembled into a system. Without proper documentation thousands of dollars’ worth of hardware can be put in a precarious situation. John Siegenthaler, P.E., a favorite speaker to the webinar series, will discuss how to accomplish this task effectively. You'll learn:
- Are you confident that you or other heating pros can service the systems you are installing when they are 10-20 years old?
- What constitutes proper documentation of a hydronic heating or cooling system?
- What are the resources available for properly documenting hydronic systems?
A seasoned hydronics leader and visionary, John shares his over 30 years' experience in designing modern hydronic heating systems with our audience. He is the author of Modern Hydronic Heating and contributes to numerous publications including Plumbing and Mechanical, PM Engineer and HPAC magazines.
Coffee with Caleffi™ technical training webinars are free and intended for contractors, designers and wholesalers.
All Coffee with Caleffi webinars are free, but registration is required. After registering, you will be immediately forwarded a confirming e-mail containing log-in details for attending the webinar. When training time comes, grab a coffee, tune in and learn more about Caleffi’s innovative products and how they can add value to your work.
If you have questions on content, please direct them to bob.rohr@caleffi.com and be sure to follow us @CaleffiUS .
Missed a webinar? No problem, our webinar archive (below) is available 24/7 for your convenience.
12 noon CST
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
