VS radiator outlet
Dave in QCA
Dave in QCA Member Posts: 1,785
edited October 2016 in Strictly Steam
Ben was working on a project a few months ago, an old church built around 1912 as I recall. The radiators in the original part of the building had these fittings on the outlet. When the cap was taken off there appeared to be a baffle of a sorts at the inlet side of the device, but it wasn't completely clear. Has anyone ever seen one of these?
Dave in Quad Cities, America
http://grandviewdavenport.com
    Steamhead Member Posts: 16,843
    I haven't. Can you get a pic of the inside?
    Consulting
  • Dave in QCA
    I will see if that is possible. The job was to install a new boiler etc. I'll see if Ben is going back for any reason and might get a picture.
