jamesgriffeth_1
jamesgriffeth_1
Member Posts: 3
I have a 2 pipe steam radiator system. It is building up too much condensate and banging in the lines. does the thermostatic steam trap at the bottom of the radiators have anything to do with this problem?
Very possible the trap has failed open, allowing steam into the condensate line. Is the banging actually in the line or in the radiator? If in the radiator, check and make sure the radiator has a slight pitch towards the trap. Is it just one pipe/radiator or multiple ones? When was the last time the traps were checked?0
the banging is in the line. When the heat is on the radiator remains cold. the other radiators are getting hot.0
Traps usually fail open but it depends on what trap you have. Post up some pics of the trap.Peter Owens
SteamIQ0 -
A good heating technician with a steam-specific skill set will be able to test your traps. They are designed to last 5 years, and though many last much longer, should be tested periodically.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
