why bother
lchmb
Member Posts: 2,997
''As long as it's runnin, it don't need fixin".Bob Boan
Outta sight outta mind. Sad to say there is a lot of this crap happening in basements across the northeast.
TaylorServing Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
Weil-McLain 68? Steam or water?All Steamed Up, Inc.
Consulting0 -
Hot water. and yes it was the 68 series.0
Usual "O" ring leak. Too bad no one caught that years ago. Could have saved the homeowner some $$$$0
I had a blown out section on my weil mcclain boiler. Previous owner didn't take care of heating system. Venting sucked, piping was horrible, leak in return. Corrected most of it, with the last small section to be finished before replacing wall & sheetrock.
Terrible feeling to have a bad boiler, specially when winter is on it's way.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
