tekmar
Paul S_3
Member Posts: 1,261
i have a job with a disconnected 4 way valve and actuator with an old tekmar 354.....system has 2 80% direct vent boilers at the moment i believe they just maintain 180F and customer shuts switch off to one of them in summer other boiker is used for indirect heater.....i was looking into the tekmar 360 with a 4 way and actuator.....but it seems it doesnt do boiler staging....is there a tekmar control that does both floating valve and boiler staging? thanks Paul s
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
347-692-4777
ASMHVACNYC.COM
any takers? tekmar tech support #?ASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
781-938-8900
FIA in the Boston area.
That's which I call with tekmar selection.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
