isolation valve insanity?
keyote
Member Posts: 659
what do you think I have the taco zone valves coming off the supply manifold, and caleffi flowsetters going into the return manifold just upstream of the webstone purge valves. I also have webstone drain valves on the pumpflanges and boiler unions s/r outlets. Now im think what if i need to service the flow setters or taco zone valves [ i think the tacos are usually able to service by just control switch out] and wonder if i should add valves upstream of flowsetters and down stream of taco zone valves is that crazy or just first rate ? these caleffies have spring checks i worry might clog how likely is a taco zone valve brass portion likely to fail?
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
