Thermostat color
That's what I like about our trade............always something new. The latest is that one of my customers doesn't like the color of the white Honeywell and White-Rogers thermostats that I normally use. I haven't started looking yet (usually start here), but is anyone familiar with a beige or off-white thermostat that I could offer?
Thanks!
  • ratio
    ratio Member Posts: 3,626
    The new Lennox touchscreen is available in silver. Judging by their last touchscreen stat, it might be a close cousin to the Honeywell 9000. ISTR that is also available in silver, & maybe black too. Maybe one of those would be more acceptable than white?
    NB: The Lennox stat requires a common--no battery holder!
    hot_rod Member Posts: 22,143
    Just a basic heat only stat? Retro look :)
    Beige was a popular color back years ago. Sometimes you can find odd stuff like that on e-bay. Often brand new, old inventory.
  • Bob Bona_4
    Bob Bona_4 Member Posts: 2,083
    Honeywell Prestige has a number of color options. From time to time I get that complaint too.
    ChrisJ
  • ChrisJ
    ChrisJ Member Posts: 15,677
    I think Honeywell's 9000 series also has changeable faceplates and colors.
    Unless that's the Prestige series? I assume they're different.
    Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment
  • ratio
    Installed my first 9000 today. It's not the same as the Lennox 5500/7500 line. Fired four stages of cooling in a 70 ton Aaon via an EIM just fine, staged up about five minutes apart. They seem like a quality part--there was an advanced option to adjust PID values!
