Preventing Condensation in Venting
Stokehold
Member Posts: 43
If a 3" PVC vent for a high efficiency power vented water heater or furnace must travel through the unconditioned space of a home (attic), what is the recommended type of insulation to wrap the pipe to minimize condensation? Is it better to use a foil backed foam wrap, fiberglass or pre slit foam sections?
Is it a condensing appliance?
Check with the manufacturers install guidelines, but my condensing boiler install manual was pretty clear on PVC vent insulation:
"DO NOT thermally insulate the exhaust vent or intake pipes. "0 -
I had looked into this for my dad as when it's -20F out the fresh air intake sweats like you would've believe. I believe the instructions to his recommended insulating the intake.NY_Rob said:Is it a condensing appliance?
What does the manufacturer of your boiler want someone to do under these conditions, just let it drip all over?
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
