Advice Needed on Radiant Plumbing
dabineri
Member Posts: 10
I wonder if I can get some advice on a radiant heating project. I have a high efficiency boiler running 4 short zones in a small house. On one circuit that currently has two small radiators I would like to be able to use the return line from the radiator, through a mixing valve to get the temperature down to underfloor range. This is for the same room using the radiators (not enough heat). The return line would come back to the mixing valve and also to the main return to the boiler and the under floor circuit would have its own pump.
My questions is,should this be attempted? I realize that both pumps must come on when heat is called for. Would this work well?
Thanks for advice.
David
Thanks for advice.
David
I think I know what you are saying, but if you could draw a schematic of what you are trying to do we will be able to help more....
to do this right you will need a lot more information0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
