What's this called?
Hilly
Member Posts: 427
Is this fitting more of a HVAC style fitting? I have seen them a few times over the years but only ever on hydronics and never in a plumbing system. Friend sent me his find today because he'd never seen such a creature before.
Perhaps it's a supply and return tee?
http://www.nibco.com/Fittings/Metal-Fittings/Pressure-Fittings/Cast-Copper-Pressure-Fittings/711-A-Supply-and-Return-Tee-C-x-C-x-C-Cast/
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
If there is a pump on the boiler, it looks to be a primary secondary loop with the branch secondaries off either side
Although pipe sizing is suspect?Bob "hot rod" Rohr
Living the hydronic dream0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
