New Wood Burning Fireplaces
NewHouse2016
Member Posts: 5
My masonry contractor is getting ready to start on my fireplaces in my new house. I have several questions: 1) Should refractory cement be used in the firebox, smoke chamber and between the flue liners? He wants to use type N mortar. 2) Should fire brick only be used in the firebox? My contractor say yes and says soft red brick for the smoke chamber. His reason for the red brick in the smoke chamber is so that they can be parged. 3) Should the clay flue liners be insulated? Was thinking about using a industrial refractory blanket type insulation. Thank You
Type n was always used in the fire box, and flue tiles. Refractory mortar is more costly, may be code in your jurisdiction.
Parging the smoke chamber is better with red brick(adhesion).
I have 5 masonry fire places done in 52. Type n was used in the box, and liners. Fire brick in smoke chambers although mine are not parged.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 879 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
