? L8124A and L6006A both for my dual fuel coal/oil boiler (hot water)
leonz
Member Posts: 1,127
Do I really need to keep the L6006A installed in the top of the steam chest and wired in parallel
with the 24 volt TT terminals when I install the new Honeywell L8124A or can I just leave
the L8124A to handle everything? I do not plan on running the boiler on coal hotter than 140 degrees
Fahrenheit on the high limit anyway and 120 on the low limit side with a 10 degree differential.
Thanks much
Thanks much
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
