downfeed monoflo
Paul S_3
Paul S_3 Member Posts: 1,261
what is the best way to connect radiators on a downfeed monoflo system?
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,513
    Always use two Monoflo tees on downfeed, and try to get the tees at least the width of the radiator apart.
    Retired and loving it.
  • Paul S_3
    this job has only one monoflo tee....i was talking about the rad top and bottom....top and top....or bottom and bottom? thanks
    347-692-4777
    ASMHVACNYC.COM
  • Hilly
    Hilly Member Posts: 427
    Bottom / Bottom, and TWO Monoflows. I don't have the science but that has always been my understanding. I'm sure I'll be corrected. But I can say for certain that I have witnessed a lot of downfeed monoflows that haven't worked on one monoflow.
  • DanHolohan
    If you feed the bottom and return from the top the air will have an easier way out.
    HillynjtommylchmbSWEI
