Weil-McLain GV-4 won't fire
Cruisinfanatic
Member Posts: 28
I have a Weil-McLain GV-4 series 1 that won't go past fan running with only the power light lighting.
After a few recycles, I did get it to light and heat for about 15 minutes, then it shut down again. Purge light began to flash.
Made an inquiry at the local heating supply store and they suspected leaking air pressure switch supply lines. I left it alone with power off for a day. Came back, flipped the power and has been fine for a few days now.
Does this sound like air pressure switch and, or vac lines?
Maybe replace the switch and the lines?
Do you have the manuals on the GV4? If so there is a section on testing pressure switch and also diagnosing flashing lights.0
I'll check those things. Looks like the switch is readily available. What about the vac lines. Anything special about them to replace?0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
