I smell exhaust?
Charlie from wmass
Member Posts: 4,322
Customer just bought the house. Brand new flue pipe by the previous owner.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating
cell # 413-841-6726
Photo of pipe that was in the cinder block foundation wall going into chimney.Cost is what you spend , value is what you get.
cell # 413-841-6726
Was it by any chance an orphaned water heater?LANGAN'S PLUMBING & HEATING LLC
Considerate People, Considerate Service, Consider It Done!
732-751-1560
email: langansph@yahoo.com
www.langansplumbing.com0 -
I think your customer needs to speak with his lawyer.All Steamed Up, Inc.
Consulting0 -
Boiler only. Customer found paying me to install 2 feet of smoke pipe not worth lawyer time. I am sure it would be different if someone died.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating1 -
I would actually consider running a bit of stainless through there.0
I recommended that they get the chimney lined. The stainless liner would then extend through the basement wall. The pipe I show was not changed when the other pipe was changed.Cost is what you spend , value is what you get.
cell # 413-841-6726
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
