Water softener
LionA29
Member Posts: 255
Any recommendations on a water softener?
Looking for a all in one cabinet style because of space.
Thank you
Thank you
For what purpose? And how much flow?Br. Jamie, osb
For whole house use with 3 showers.0
It has a hardness of 8.0
There are all kinds of water softeners out there -- and a number of companies which specialize in them. Not to mention being able to buy them from the big box folks and even places like Sears.
Is that 8 figure in "grains"? A unit which I deplore? That's really not that high, and most units will do that just fine.Br. Jamie, osb
It was tested by a company who markets softenor. I think it's 8 grains. There is significant scale build up on shower head that is just 3 months old, shower door and also dishwasher. I was looking at Fleck 5600SXT cabinet style.Dont know if anyone had any experience with them.0
That figure of 28 grains puts things into perspective.
The salts in the water coming out of the softener must have some detrimental effect on the longevity of the hot water heater, and boiler.--NBC0 -
In excess of 40 grains in some areas.http://funkyfluff.ca/water-hardness-in-canada/
Dual head softener a are another more $$ option. It assures you never run low on soft water
Opinions on soft water in boilers vary, many now agree soft is better than excessive hardness
Ideally boiler water is demineralized, not softened. DM is not an ion exchange,no sodium substituted. The residual conductivity from softening raises the conductivity which can increase electrolysis
Water quality in hydronics is becoming a huge issue as chlorides in our public supplies continues to increase
Pay close attention to what the boiler manuals suggest if you ever have a warranty issue, water quality will decide who covers a replacementBob "hot rod" Rohr
Living the hydronic dream0 -
It's sodium bicarbonate not sodium chloride after the ion exchange.0
Error0
Yup. They don't work.Br. Jamie, osb
Almost done with my new fresh water make up water line bypassing my softener with chlorine filtration.
Must say, water quality is way better than what I had!0 -
Hi, I'm considering installing a new combi condensing boiler. One of my concerns is that I live in an are with hard water. I would like to avoid using a salt based water softener. What is the best salt-free option?
Thanks!0 -
Depends on what results you are looking for. Salt free type do not remove the hardness minerals, they change the structure, supposedly, to keep them from scaling out into pipes and appliances.
A true ion-exchange type softener removes, or exchanges the calcium and magnesium with the brine solution.
This dealer does a good job of explaining the differences.
http://idahowatersolutions.com/water-softeners/the-truth-salt-vs-salt-free-water-softeners/Bob "hot rod" Rohr
Living the hydronic dream1 -
See my comment on the other related thread. If you want to reduce the hardness and total dissolved solids for use in a boiler, reverse osmosis is by far the best approach. Other softeners do change the mineralogy or the structure of the dissolved solids, but they don't reduce the total dissolved solids and, while they may reduce scaling (or may not), they either do nothing to the corrossivity of the water -- or increase it.Br. Jamie, osb
I would agree with above, use a reverse osmosis filtration system.0
If your water quality is poor I would not consider a combi boiler...at least one that uses a brazed plate heat exchanger.
You asking for a lot of clogging and poor hot water issues down the road.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
