tekmar 361 mixer
bagogeo
Member Posts: 2
how do i know if my system pump is staying wide open,since i have to keep my boiler temp at 140 f to keep my pex at that temp otherwise raising my boiler temp raises the supply zone temp equally,my 361 mixer is showing no errors and all the field dispaly numbers are correct....is there a way to test the pump to check for opening and closing,or could my 361 board be keeping it in the open posistion?
radiant system pump help0
Do you have picture or drawing of your piping arrangement?
There are several ways of configuring these. It is important to know your setup."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
