Uponor vs. Watts
johntrhodes81
Member Posts: 42
For the runs to baseboards/Rad in a hydronic system I am planning to run Pex-AL-Pex. One Supplier has Watts pex-al-pex and Watts pex-al-pex Compression fittings. The other place I am looking at has Uponor Pex-AL-Pex but only Mr. Pex or Rifeng Brand pex-al-pex Compression fittings (they also have RIfeng pex-al-pex). I am not really keen on buying the $760 Uponor MLC crimp tool to crimp 24 connections.
Any opinions on Watts with Watts fittings or Uponor with Mr. Pex or Rifeng fittings?
I did check the supplier says Uponor is compatible with the compression fittings.
Thanks,
John
Thanks,
John
I sell and used the Viega fostapex tubing and fittings pex press type fittings in my house.
The fostapex tubing is great and so are their pex press fittings.
I was told compression fittings can come loose with time.
I also do not like insert pex fittings with orings
Where are you located? Some wholesalers who sell the Viega fostapex tubing also rent the prep tool and press tool.0 -
I am probably over thinking this but fostapex requires removing the outer layer to use the fittings. This is where the oxygen barrier is. Doesn't removing the oxygen barrier at the fitting defeat the purpose and let in O2? I had been avoiding fostapex for this reason. Maybe I am over thinking this.
John0 -
john your over thinking, the fostapex purpose in my opinion is so the pex doesn't sag and take shape for where it has to be installed0
Ok, So your saying that Fostapex shouldn't let in more Oxygen than competing PAP, so I shouldn't worry.0
Don't worry. They both need to meet the same standard. Both are approved in the City of Chicago for the application you have. That says a lot.Steve Minnich0
Thanks.0
Don't forget Radiant Engineering, who actually invented them (and offers them in more configurations, including longer lengths) http://radiantengineering.com/productsthermofin/0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
