some fittings that you might find helpful
hot_rod
Member Posts: 22,024
We are adding press fittings to our product offering. We offer up to 2" press on the separator products.
1/2- 1" press is via a nut and tailpiece fitting. So you can build a large number of combinations. Any valve or device with a 1" G thread can be adapted onto with a union connection.
Here are some 1/2 - 1" examples. We have quite a few ways to transition from a Euro straight thread if you have a special application. The one example shows a transition from a galvanized WH nipple to press, or press to sweat.
Let me know if I can help with any assemblies.
Any F1960 options? Uponor sells a couple of sizes (as manifold adapters) but not a full range.0
So a F1960 manifold connection? The manifolds are about the only place we transition to pex.
Sioux Chief has a lot of F1960 adapters, maybe I can rig one up to go to the manifold thread.
That lower left ring turns the manifold port thread into a 1" G, now any fitting can transition onto that. It was built to put 3/4 or larger copper onto a manifold port. It would be a two step solution.Bob "hot rod" Rohr
Living the hydronic dream0 -
I was actually thinking more along the lines of mixing valves, pumps, and hydro seps. Feeding manifolds is another one, but radiant is (unfortunately) less than 20% of our business these days.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
