2 days of vacuum
Fizz
Member Posts: 547
Replaced dry return vents(Richardson System only has vents on dry) with vacuum vents 2 days ago and set thermostat to hot water(3cph). Results very good. Steady heat, and comfortable heat in 2 rooms which never got to comfort level. In midst of sub-zero night temp and worked fine. Took the advice of PMJ. Will see what rest of season shows. Was concerned because system 100 yr old, and 3 rads were add-ons with regular traps.
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
