Venting mod con (Bosch Greenstar) through unconditioned space before terminating outside
Ross_24
Member Posts: 82
I cannot find any information on this. Does anyone know the requirements for running a vent from a basement into an unconditioned space (let's say a garage) and then out the garage side wall?
Is this possible? If so, are there any listed requirements for vent materials and insulation lengths for this specific situation?
Thanks guys!
Thanks guys!
I agree. That's what we've done in the past.njtommy said:I would insulate the exhaust and make sure the exhaust is pitched currectly to minimize any water laying in the piping.
I'm just surprised I cannot find any literature on this. Some guidelines for this situation would be helpful.0 -
Here's a tech bulletin for venting the GB142 through an unconditioned space. I would think the same applies to the GreenStar.
http://www.bosch-climate.us/files/201001220052570.TBG-5_Guidelines_for_venting_through_an_unconditioned_space.pdfBob Boan
You can choose to do what you want, but you cannot choose the consequences.1 -
Exactly what I was looking for. Thank you!Ironman said:Here's a tech bulletin for venting the GB142 through an unconditioned space. I would think the same applies to the GreenStar.
http://www.bosch-climate.us/files/201001220052570.TBG-5_Guidelines_for_venting_through_an_unconditioned_space.pdf0 -
3 inch CTS insulation (3-1/8" ID) fits 3 inch Centrotherm perfectly.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
