Steam heated kitchen warmer.
LES WEGENER
Member Posts: 7
Here is a picture of two steam radiators piped and installed in a metal lined kitchen cabinet. The steam is no longer heating this mid 1800's house and someone has removed the supply valve and riser, but you can still see the air vent poking up in the left rear corner.
Is there any chance that's actually a plate warmer?0
It's certainly not there to heat the room.pecmsg said:Is there any chance that's actually a plate warmer?
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
Nice way to keep prepared food warm, at least during the winter months.0
What happened to the steam?LES WEGENER said:Here is a picture of two steam radiators piped and installed in a metal lined kitchen cabinet. The steam is no longer heating this mid 1800's house and someone has removed the supply valve and riser, but you can still see the air vent poking up in the left rear corner.
So...Can I have it?0
Weren't those plate warmers sold already assembled like that?0
Yes, a bunch of manufacturers made them for that purpose.Retired and loving it.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
