Adding Sound deadening Insulation to a Lochinvar WH
ced48
Member Posts: 469
Any reason not to add some 3/4" sound deadening insulation to the inside cover of a Lochinvar wall hung boiler? They switched to a fiberglass cover with insulation on their Cadet series of boilers. I was thinking this might quiet down, what is already a quiet operating boiler, just a bit more. Only problem I can think of might be the computer?
I don't see why not... the bottom and top aren't sealed at the penetrations, so heat should still be able to pass thru.
I believe yours is inside a closet, right? I think you'll be much better off sound-proofing the closet (interior walls) than the 1" or so of material you might add inside the panel (likely to do nothing).
Also FG is a terrible sound deadener... I would go rockwool, roxsul, mineral wool preferably. If you have walls of the closet to work with, you can add mineral wool and even a layer of foam acoustic "wedges". Also seal the opening/door... as sound will just leak out the gaps...0 -
Yes the boiler is in a closet. First it had a louvered door for air circulation. I switched to a solid core door on advice from one of the techs at Lochinvar, but switched back to louvers when another tech said I needed the air circulation to keep the heat down. I was thinking of using an auto hood insulating material.0
I can't imagine it requires a lot of circulation, especially when your drawing intake from the outside... I'd put the solid doors back on and stick a thermometer in the closet and monitor the temps for a while. You could always run a supply/return duct from the closet to some other location if you need the keep temps down.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
