Thermostat for 1 pipe steam
General
Member Posts: 120
We need a new thermostat for our 1 pipe steam as our old one will no longer hold the program. Is the Honeywell TH6110 still the recommended one? We don't care to program from our phones but do want to be able to program setback at night and on weekends.
As long as your system tolerates a setback well the TH6110 is fine. I personally prefer the VP8000 series with it's touch screen but the 6110 will perform good.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0
Thanks, I will check out both of those.0
What are you having trouble with exactly?General said:@Chris...on the T6110 are you talking about the installer set up functions? We have the thermostat and are trying to figure it out. Thanks!
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
In the book under installer settings there is a set up function...5 is stage 1 heat cycle rate and 6 is stage 2 heat cycle rate. Both settings are for gas or oil furnaces of less than 90% efficiency. With each of those settings you can then choose a secondary setting of #1 for steam or gravity....we set it to 5 and 10
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
