fresh air damper
bklynfrank
Member Posts: 15
I have an 18"x18" duct bringing in fresh air for my steam boiler. I'm thinking of limiting the cold air when the unit is off with a motorized damper. Any suggestions on model or make that has a sensor that will break when it is closed?
There should be two openings, one high and one low. Can you post a photo showing the duct termination, boiler, and surrounding area?0
A single opening up high can provide a certain amount of air for combustion, but it will not allow CO2 (which is always heavier than air) and CO (which becomes heavier than air in cold weather) to escape from the room.
Personally, I will not install a natural draft boiler below ground level without (at a minimum) a double-acting barometric damper and spill switch. Mechanically assisted combustion air would be better, and (if properly designed and installed) will actually reduce net infiltration to the building.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
