Rinnai ru98
pkover3
Member Posts: 2
We have a rinnai ru98 that has worked great for three years. Last week for the first time the water would not warm up. I unplugged the unit and plugged it back in and everything seemed to work fine again. About a week later the same thing happened. The unit was flashing error code 11. I unplugged the unit and plugged it back in and it is working again. I have a feeling it will happen again soon.I read through the manual and saw that it can be the igniter. how do I test the igniter to see if that is the issue. Thanks for any advice.
the igniter may just need a good cleaning. use a dollar bill to clean off any reside. The manual should tell you what covers to pull off to gain access.0
I will give that a try. Thanks kcopp.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
