Steam heating Dos and Don'ts for homeowners
HeatingHelp
Administrator Posts: 635
For lifting a radiator a 3 ft 2X4 and a fulcrum are your friends. They allow you to easily and slowly lift the end of a radiator in a controlled fashion without hurting yourself. Then you can slide a shim under the radiator feet.
3PSI gauge0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
