Electric Dampers won't work
tymckz
tymckz Member Posts: 1
edited December 2015 in Thermostats and Controls
I have an old Trol-A-Temp Honeywell damper control. Two of the dampers are stuck open and 2 are stuck closed. I'm guessing none of the dampers are getting any power. The first bar on the circuit board is registering power. The following zones do not seem to be getting power. The furnace works just fine. 2 of the rooms are getting a lot of heat. I don't know where the problem lays. The wires on the circuit board seem fine. The thermostats work fine. Dampers... nothing.
  • Abracadabra
    Abracadabra Member Posts: 1,948
    When you flip the switch for a particular zone, can you feel the relay click? Does the damper open/close when you flip switch manually?
  • John Mills_5
    John Mills_5 Member Posts: 951
    Donate that to the Smithsonian and replace dampers and panel with a modern one that has a plenum sensor to avoid overheating & coil freezing. Get one with staging so you can get a 2 stage furnace in the future - perfect for zoning.
    Bob Bona_4
