Water shooting out of vents
headofsteam
Member Posts: 3
I've got a property in Bay Ridge Brooklyn and am looking for a recommendation for a "stream guy" that knows what they are doing. I've had a few other plumber in but they have not resolved the issue and think may have made it worse.
I've got water coming out of my basement air vent and a few of the apartment radiators as well (on 2nd floor).
I know the pipes in the the basement need to be insulated (is this a plumber or someone else I can hire?), I need additional air vents as the basement only has one (some knucklehead seems to have caped the other run years ago).
I have checked steam pressure and tried cleaning the boiler but have not had much luck. I'm now out of ideas and don;t have time to work on it myself and any of the guys I have used before dont know what the problem is either.
You've probably got a clogged, or partially clogged return line. Also, check your pressure settings, you may have a clogged pigtail, faulty pressuretrol, etc.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
how does the return get unclogged? do I break the pipe and snake both sides?
does gateway do any work in my area?0 -
Gateway does lots of work in your area and it's mostly steam heating jobs. Most recently we did some major upgrade work on Marine Avenue. Give the office a call if you'd like. 718-980-0909Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes0 -
Thanks for the call!Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes0 -
Please let us know what happens!Two-pipe Trane vaporvacuum system; 1466 edr
Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
