Radiant pex fittings - poly or brass?
crobar
Member Posts: 4
I am running some pex piping to a couple of hot water radiators. I can't find any info on the temp. limit for the poly fittings - are they OK to use on the heating system piping or only for potable systems? Thanks.
I wouldn't even use poly fitting for domestic.... unless its Uponor (cold-expansion joints).0
I've had 0 issues with Uponor or Viega EP fittings for heat.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
