Hermen Nelson hijet unit heater capacity
Solid_Fuel_Man
Member Posts: 2,646
Hi all,
Going through the shop and found a couple of old unit heaters. The one in question is a HN hijet model 1201, appears to be from the '50s or earlier with a two blade fan. Wondering if anyone has a chart on that the output would on water. Appears to be steel coil, manifold single pass parallel flow. Couldn't find anything on HN site.
Thanks for the vault of info this place always is!
Taylor
Taylor
Any old books or files out there on Hermen Nelson? All I can find is for their univents.
TaylorServing Northern Maine HVAC & Controls. I burn wood, it smells good!0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 879 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
