Black iron gas pipe next to supply duct - hot to touch
WScott84
Member Posts: 2
in Gas Heating
The black iron gas pipe enters my laundry room next to the supply duct exiting the air handler. It rubs up against the supply duct for a couple of inches. When I run the furnace, the supply duct gets hot, and the iron pipe gets hot to the touch, but not too hot to touch. Should I be concerned that the iron pipe is getting hot? Will this heat affect the pipe tape or dope on that elbow where it gets hot?
The gas utility in my area pre-heats their gas for delivery. I suppose that the warmer the fuel is prior to ignition, the easier it ignites and subsequently releases its own energy. Yes, no?0
Thanks for the reassurance. My thinking was hot gas equals higher pressure, meaning high risk of leaks being formed, or even explosion, but maybe it's not even getting close to hot enough if my hand can rest on it without getting burned. What is really hot and does burn your skin is the flue pipe coming out of the furnace, so I am glad the pipe doesn't touch that.0
You're heating a few inches of pipe in a system that contains dozens of feet of pipe. The starting pressure in the pipe is less than one PSI. The fluid is a gas. Don't worry.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
