Baseboards cold - Circulator Pump Hot
reghi
Member Posts: 17
in Gas Heating
If the baseboards are cold and the circulator pump is hot to the touch, is the circulator pump bad?
Make sure the loop is not air bound. If the loop has no air in it then yes the pump is bad.
Thanks Aaron, it was actually air, because after I bled the lines it worked like a charm.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
