Water Changing From a Gas to a Liquid
wt
Member Posts: 13
If I create steam inside a metal gallon can, then cap it and let it cool, the steam inside will change states back to a liquid, and in the process implode the can flat as a pancake. I think this phenomenon is strictly limited to the change of states (1700x to 1x) but my daughter believes that this is connected to the disparity between the air pressure inside and outside the can. Can anyone settle our quarrel?
Both. When the steam condenses, it shrinks 1700 times (i.e. to 1/1700th its volume as steam) which pulls a very deep vacuum. Now the pressure on the outside is much greater than that on the inside, which causes the can to collapse.All Steamed Up, Inc.
Consulting0 -
Thank you both!0
I made this demonstration every time our latest olive oil can was empty!--NBC0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
