Having Trouble Finding This Fitting
hvacfreak2
Member Posts: 500
I have some of these floating around somewhere but of course when I need one they are nowhere to be found. I figured I would just purchase a few but I can't seem to find this item or a 1/4 by 3/4 MHT adapter ( as a solution to accomplish this with 2 fittings ). Any leads or suggestions for this are appreciated.
hvacfreak
Mechanical Enthusiast
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV's
Easyio FG20 Controller
Thanks very much , that is a little more than I was looking for , but it looks like the manufacturer does offer what I want. I'll contact Grainger and see if they can get it.
hvacfreak
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV'sEasyio FG20 Controller
Doesn't Webstone make all that stuff?
I order isolation flanges and combination fill/purge valves from them all the time.
http://www.webstonevalves.comContact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
I looked through the webstone site and did not see that specific drain valve , or close really. It looks like they have incorporated the drain vale feature into the castings on many products.hvacfreak
It looks like Victaulic has one . Seems extreme for something that should be a hardware store item.
hvacfreak
You're looking to install this on your MegaSteam's sight glass, right?All Steamed Up, Inc.
Consulting0 -
10-4 , on the sight glass. I was wondering if they would get mad if I porta-banded the unused door ear off. I also use these fittings at work for dry cooler venting emergency stuff , I have some of this coming up.hvacfreak
We've done that- no worries.All Steamed Up, Inc.
Consulting0 -
Cool , appreciate the info. Tomorrow I'm resolving the draft issue , changing the pump ( I have the warranty replacement ) , getting my combustion numbers , and folding up the chain vise. Oh and I received my pressure gauge today , kind of curious as to what I'm operating at.hvacfreak
Dahl makes a drain valve in that configuration:
http://www.dahlvalve.com/products/mini-ball-valves/hose-boiler-drain/iron/hose-boiler-drain-121-61-04.phpAll Steamed Up, Inc.
Consulting0 -
I did see that one but I'm not sure who sells it.hvacfreak
Watts has them also. Do a google search and online suppliers will pop up. Put in a name and part number.Bob "hot rod" Rohr
Living the hydronic dream0 -
10-4 on the google , the Dahl search did not reveal anyone selling that item , only a few company links regarding it.
I was thinking that the ones I have stashed somewhere are Watts , but I was not able to find it on thier site. I'll give it a closer look or contact them. Thanks for the suggestion.
Man I stayed up way too late looking at controllers , there is some cool stuff out there ( even for my budget ).hvacfreak
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
