Enerco model 4040 I PP
pbbraun
Member Posts: 1
I bought the Enerco model 4040 l PP heater, serial number 022571 and I would appreciate your help in determining if the unit is complete. I have attached pictures of the unit. I really thank you for your help.
I assume that to test the unit I would attach it to a propane tank, open the tank valve, turn the control knob to pilot, and light it with a match at the point under the burner (last picture)...
Thank you so much,
Thank you so much,
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
