furnace won't light
ray762
Member Posts: 1
have a Intertherm furnace with a united technologies 1018 controller, controller hums then clicks and flashes twice, so I'm assuming a code 22, the legend is gone, anybody know the code or where I can find them?
thanks Ray
thanks Ray
Is this the controller?
If so, this has a troubleshooting guide.
http://mesteksa.com/fileuploads/Literature/Applied Air/Direct-Fired Units/IOMDFL-4.pdf
"Power/Status LED
A solid green LED indicates power and normal
operation.
A slow blinking green LED indicates power but the 10
second start up delay has not completed.
A fast blinking green LED indicates the the inpput
signal is out of range or may be reversed."Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
