Gunky/Dirty Look to Gauge Glass
Jeff_H
Member Posts: 37
I have a one-pipe steam heat system with a recently installed Burnham IN-6 boiler (I just converted from oil to gas heat). The new boiler has not run much, - a few times to test it and a few times last week with the cold weather - but the gauge glass is taking on a rather gunky look (I have attached a picture). Should this be of any concern? If so, would anyone have thoughts in what to do?
Thanks!
Thanks!
That boiler probably has to be skimmed, did the installer put a skim port on it?
A new boiler introduces oils into the system and those oils have to be skimmed off the surface of the water. Call the installer and tell him the boiler has to be skimmed and make sure he installs a skim port if it does not already have one.
3PSI gauge1 -
A couple years ago, someone posted a video with a hose blowing steam, then introduced a tiny amount of oil. It then looked more like a garden hose, than steam.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
